Am I nuts to consider this?
It's crazy :D
Apologies, forgot about the acc thing!
Engine
Cicra 350whp
Comptech Supercharger
Comptech After cooler
11lb boost pulley and Gator belt
10w60 PETRONAS Syntium racer Oil
Denso plugs (new)
Stage 3 Competition Clutch
Lightened flywheel#
750cc Injectors
AEM ECU - Tuned by MASE
Fixed trickle charger closed bonnet charging
Spoon Earthing Kit
Spoon Sparkplug cover
Spoon Rocker cover
Spoon Thermostat
Spoon Themo-switch
Spoon Radiator Stays
Spoon Oil Cap
Spoon Radiator Cap
Spoon Cool Coolant (installed)
Spoon Race Battery (summer months)
AEM AFR gauge in pod (new sensor)
SPA Oil temp gauge and Greddy sandwich plate
Exhaust
Spoon 4-2-1 manifold with heat wrapping
Spoon Cat Pipe From an N1
Spoon Muffler Kit (like an N1 but one piece - very rare in UK)http://www.gotuning.com/product_info.php?products_...
Bodywork
Spoon Front wings (fenders)
Spoon Rear arch extensions
Spoon TAI Front Bumper + fog light kit
Spoon TAI Rear Bumper
Spoon Rear Diffuser
Spare wheel removed
Boot lining removed
Spoon Titanium Gear knob
Spoon Rear Diffuser
Spoon GT wing
Suspension
Comptech Strut Brace
Tein monoflex coilovers - fast road setup by TGM
5.1 Brake fluid
Hardrace driveshaft Spacers
Braking
Good ridge Brake Hoses
Spoon Brakes disc's all round
Spoon Calipers
Spoon Front Brake Pads
Standard rear pads
Wheels & Tyres
Rays 57 Motorsport wheels
Bridgestone RE050s all round
Spoon Wheel Nuts
Eibach 20mm rear Hub centric Spacers
H&R 15mm front Hub centric Spacers
I wouldn't be able to stop laughing at the 'SPOON' sticker in the rear window if I pulled up behind that. :D
Si
You've done this, get the car you really want mate, so save and get something you really enjoy.
This is 20k, that's CSL money or decent Cayman money and having owned/driven all three the S2000 is the weakest link, though the S2K is an amazing car!
