What's the performance bump in 3D Mark 11 like between that and a 3930K? Don't know the difference between the two and too lazy to search.
a little bit, but I can only run my board chip at 4.7ghz (down to board being rubbish) so the extra 300mhz jump should yield an increase in speed.
Clock for clock the 3930 and 3960 are exactly the same in 3dmark11.
Going from 4.7ghz to 5.0ghz on mine adds about 700 to the graphics score. It also gets me over 17000 on physics.
So do you both have any clue to what speed you would require for your CPU to stop being the bottleneck?.
Most of the scores on the hall of fame are clocked at 5.0 or slightly higher. Thats running 4 gpus so it would be around 5.0 - 5.2ghz. If you can go higher it will still increase your score (the higher cpu clock will push up the physics score).
The other thing about 3dmark11 is its just a benchmark where you can see fps getting close to 300. This is way more than I would see in a game with settings maxed out. For gaming I don't go higher than 4.0ghz and don't have a problem with bottlenecking.
.New scores all round, though it doesn't move me up any in the main standings it does move me up in the GPU scores (couldn't be bothered re-tuning my CPU OC and memory timings).
http://www.3dmark.com/3dm11/4444032
Haha even if I did you have that 3930k on the way....
I am upgrading this way, as I am bottlenecked in some games and only seeing a max of 85% GPU usage.
I am happy with the fastest score in the GFX, if you beat me, it will remain that wayI am upgrading this way, as I am bottlenecked in some games and only seeing a max of 85% GPU usage.
I did hear about the possible bottleneck from the 2500k chips with multi cards. What motherboard are you going to pair the chip with?
Is this something related to the 2500k or does it affect the 2600k and 2700k for example.
)I'm positive I saw a chart perhaps on ocn that showed a bottle neck on a 2500k but no bottleneck on a 26/700k with ht enabled, ht disabled the bottleneck showed up again, this was on bf3 which must make use of ht.
In short, more cores/threads are better for avoiding a bottleneck on multi card setups.
