- 19 Oct 2002
- Shakespeare’s County
I never knew this, I was under the belief that they were closed until they started to heat up and opened at the rated temp for the engine.
That must mean that cars that have overheated due to a thermostat that was stuck shut has been another fault and that the thermostat I recently replaced on my wifes car is faulty as that was shut when it was cold too.
They slowly open and close with the temperature gradient. Also the jiggle pin that allows a small amount of water through (and for degas) will drive a current through the water. Partly open obviously will restrict flow so it may cause overheating.
Radiators are massivly effective at cooling air, if the stat opened fully only at 80C as soon as that stat opens you swap 80C water for 10C...... so your heated would go cold and you run the risk of thermally shocking the engine.
