Caporegime
- 9 Nov 2009
- Planet Earth
Saw this on Techspot:
http://static.techspot.com/articles-info/577/bench/PhysX.png
They are using a six core SB-E CPU at stock clockspeeds,but still it means if your have a reasonable CPU you can run PhysX enabled with an AMD graphics card.
You need to edit WillowEngine.ini and set the PhysX level to 2.
I would advise setting it to medium if you don't have a nvidia card to do the work.
