regards
I hope this gets sorted by morning for ya buddy. Is there no option to install the code outside steam? I'm guessing it's a steamworks game. Could always try it on gmg and other places lol see if it registers.
If this is a boxed retail version. You need to contact Steam or the game developer directly.
More than likely someone has 'keygened' your code and is using it if you have tried all the possible codes.
Steam are usually good at sorting things out through their support, they will more than likely reset the code directly and email you another one. They may ask for proof of receipt and a photo of the box to prove that you are the real owner of the key.
Yeah I have contacted steam support seems a lot of hassle if I have to take a photo etc
Thanks
It is a shame for those who have purchased genuine copies. I am sure they will sort it as soon as possible. Their ticket system is pretty good, and I have seen people get a quick turn around. Good luck!![]()
just I was hopinG to have played this on friday but with it being delivered late and busy weekend then getting time to sit down and play then this
I apreciate all the replies,help.You aren't entering the code for the dlc by mistake are you? When you open the box there is a leaflet for the dlc with a code, but the code to auth the game is on the actual instruction book.
The reason I say this is that I tried entering the dlc code first, but realised my mistake. You will get an error from Steam if you do that before entering the code for the actual game.
Hope this helps.
Try entering the code again.
Make sure caps lock is on & make sure you put the - in whenever you're supposed to.
gGet ready for your head to swell, amazingly putting caps on worked!
was there somewhere you read you had to do this?gGet ready for your head to swell, amazingly putting caps on worked!
People might think thats obvious but it isn't as there codes only let you put in caps with caps lock on or off, i suppose this is to make it easier so we don't have to worry what case we are in. But it worked with caps on so i'm happywas there somewhere you read you had to do this?
Regards
Enjoy your game!!!Have you entered the code in correctly? It's surprising how many people blame something else when it's usually their own fault.
Sorry but I disagree with that statement as when you put in the code it automatically puts it in capitals and the code itself looked exactly the same as the printed version all caps with spaces how was I suppose to know you had to have caps on? I have put codes in games pc,consoles for 15 years never had this problem before.
Thanks
