- 15 May 2012
- Louth, lincs
@Nelly, you may want to add the HP usb disk format utillity to your first post as i could not flash bios without it when using the msiHQ forum tool
@Nickolp1974
Does the Bequiet cooler not fit rotated anti-clockwise 90degrees?
Good idea, I'll add it, its a good option, used to use it all the time to flash my old Abit IP35 Pro. If that doesn't work, I'll have to dig out my floppy drive I think lol.Nickolp1974 said:@nelly, you may want to add the HP usb disk format utillity to your first post as i could not flash bios without it when using the msiHQ forum tool
I do like the way the top is finished on those coolers.
It could be a problem with the MSI tool and the board, that Svet on the MSI forums updates the program every now and again, if their is any issues. I think he's Russian and it just so happens the guy who does the MSI After Burrner is Russian too I think, wonder if it's the same guy lol.
WARNING:- DO NOT USE THE WINDOWS MSI LIVE UPDATE 5 METHOD TO UPDATE YOUR BIOS, HIGH RISK OF BIOS FAILIURE!
Latest Beta BIOS >> BIOS ID: H42
Please note that flashing this release occurs entirely at your own risk!
>>Use the MSI HQ Forum USB flasher<<, Method II for best results.
Do NOT use the BIOS/UEFI integrated M-Flash Routine.
E7751IMS.H41 ==> E7751IMS.H42
- Update the CPU Micro Code M12306A9(015).
- Fix UpdateBiosAndME function issue.
- Fix Possible Black Screen issues with GOP Driver.
- Fix Avexir 2400(patched before) S3 wakeup failed.
- Update Realtek uefi driver.
- Update CryptoPkg Module 010.
- Fix Winxp 64bit S4 error issue.
- Update Intel Ivy CPU GOP ivy_30131013T01.
- Fix post code show error issue.
- Release Date: 27th September 2012
2 +4 are the ones you should be using if you have 2 sticks of RAM.
Just installed my stuff today, 3770k and 8GB of Kingston 1600Mhz. Going great so far, though I am thinking my HD6950 is going to hold me back.
Haven't seen the CPU boost yet, apparently on this board all 4 cores can boost to 3900Mhz. I think. I read it somewhere.
Anyone pressed the OC Genie button yet?![]()
