I can't get a Z4 Coupe for less than about 7-8k can I?![]()
[TW]Fox;22845331 said:To properly replace it I think you need to spend proper money otherwise anything you get will be slightly better in some areas and perhaps not as good in others, or not better enough or newer enough to justify the hassle of changing.
8k would buy you one, most likely a pre facelift so if you're happy with the running costs and owning a ~2002 car then that would be my choice. Would you be happy with a higher mileage car? The S54 is a very solid engine and can take big miles.
http://forums.m3cutters.co.uk/showthread.php?t=61893
Hmm. It's a logical progression isn't it.
My yearly mileage is a good 15k so I wouldn't want something too leggy, that I'd have to replace worn out or broken parts on every 5 minutes. I wouldn't want a bottom of the barrel car.
I thought the M3 never got a facelift? Or was it just that it never got the facelifted front end?
)- probably due a suspension overhaul? This is the problem wtih these now, almost all are at a stage where a pile of cash needs to be thrown at them to get them back to their best - but many have long been in the hands of people who cannot or will not spend the money, or would rather spend the money on new wheels or mods.[TW]Fox;22847341 said:Only a single wishbone in all that time (Why only replace one)- probably due a suspension overhaul? This is the problem wtih these now, almost all are at a stage where a pile of cash needs to be thrown at them to get them back to their best - but many have long been in the hands of people who cannot or will not spend the money, or would rather spend the money on new wheels or mods.
[TW]Fox;22847330 said:It got the facelift at the same time as the rest of the Coupe/Cab range - just not the front end.
