Question.
What the bios flash enabled it to do was to install a PCIE-bridge or something like that, as soon as I saw that installing I knew it would work
Thank god this forum exists. You're all so patient! lol
Glad you got it sorted :)
A few have users have had this issue, problem with a sticky no one usually reads them :p
As the Gpu problem is common with this board, a little note in the Motherboard section or a foot note in the Mobo product description would help.
Hey guys, thanks for all the help btw.
This machine destroys any game I throw at it, DayZ runs at 60+ fps with everything maxed and bf3 runs at 50+ fps with everything on ultra, though is it normal that my cpu temp would be at 60 degrees when playing BF3 at those settings?
Glad to hear it's up and running :)
Is that with stock cooler and no overclock? I've never run a stock cooler, so I don't know what to expect from them, but I'm sure someone around here will. 60deg is still a safe temperature either way, nothing to worry about.
