That's a lot of climbing... Well done on pulling that off!
Tell me about it, I hurt n places I never knew existed! Thanks
It's small, it's a 20.5" - but bear in mind it's a TT frame so probably supposed to be low at the front with aero bars on it and a long seatpost like I ride it.[DOD]Asprilla;22865818 said:What size is the Bob Jackson?
Wow, that's some shocking quality control from Garmin there.
I just did my first commute home on the road bike, smashed my best MTB time by 7+ mins
I can not believe how much faster the road bike is, was concerned i would spend the money and not get much difference but im blown away!
Bit concerned about my heart rate 183 average and 203 max - as im 34 im sure it should be vastly lower, im blaming the technology as im not dead as yet![]()
You'll need a track pump if you have a road bike full stop really. Got a puncture today and it took like 10 mins to pump the tyre up to a responsible pressure with my micropump, shoulda not cheaped out and got a double pump one i think.
It'll say it's good for 160 psi but you'll struggle to get past 100 with even the best mini pump.
I got a good pump that i have attached to the frame, i use it on my MTB at the moment (but its designed for road goes upto 160 psi) and it inflates quick enough, dont think its a double pump though
really? that sucks![]()
I was actually just thinking of asking for some recommendations for a CO2 inflator.
I tend to stick a normal mini-pump in a jersey pocket for when I'm out on my Road Bike for emergencies. Using strong puncture resistant tyres, I've not had to resort to using it very often. I'm planning on entering a couple of Sportives in a few weeks time, which made me realise that if I did puncture, messing about with a pump which won't even reach the correct inflation would be a huge waste of time.
It would also be useful on my mountain bike, as despite the lower pressures, I run tubeless which requires high pressure to create a seal to get the tyre on.
M-part CO2 pump is very good as it screws onto the valve and has its own valve to control flow. It's also one of, if not the cheapest CO2 pumps you can buy:
http://www.parker-international.co.uk/17178/MPart-Micro-CO2--Pump--inc--2-Cartridges-.html
Parker now want a minimum £30 order for free delivery so I don't doubt you could find it somewhere cheaper including delivery.
-edit- here a bit more but free delivery:
http://www.tredz.co.uk/.M-Part-Micro-Co2-Pump-Including-2-X-16-gram-Cartridges_35410.htm
£1 cheaper:
http://www.amazon.co.uk/dp/B0037SGK...de=asn&creative=22218&creativeASIN=B0037SGKBA
