In a word yes, I think Intel CPUs still have more "CPU power" but their integrated GPU doesn't compete with AMD's offerings.
As you said, in the case before, if you wanted more graphics then you'd simply spec a decent, capable card for your requirements. A bonus of the AMD setup is that if you buy say, a 6670 afterwards you can run Crossfire with the APU giving you a boost but I think it only works with certain graphics cards of the same family to the APU or something. Basically you couldn't whack in a 7950 and link it to the APU.
In a nut shell they are great for media PCs as you haven't got a power hungry graphics card and you do away with the extra heat and noise of having one makes. But on the other hand you may fancy the odd run of something when your mates pop over and it will be able to get decent frames.
