Do you guys with the bitfenix pro fans have them on a fan controllers as looking at the stats they look like they would be noisey?
A small mod ive done to the front mesh filter on the 650D, i wasn't over keen on the criss cross look of the front filter plus it would reduce air flow slightly.
To do it take away the mesh by lifting the clips up and slide the plastic frame out, to cut through the plastic i used a stanley knife, i warmed up the blade on the cooker and it cuts through the plastic like butter. It really improves the front look of the case and makes it so much cleaner looking, its hard to do it justice in pics.
avez vous got any pics of it covering the top of your case? Merci.
-Le French Man![]()
I've just ordered up some Bitfenix Pro 200mm fans last night as the standard Corsair ones are rubbish and the top one keeps clicking!
I've also ordered a 120mm Fan Filter for the rear of the case.
I'm thinking of Having 2x Intake Fans and 1x Exhaust. Good or bad idea?
The rear 120mm fan will have the filter on, and will be used as an intake as it draws cool air through my Kuhler 620. The front fan will also be an intake.
Then the rising heat will exit the top of the case via the 200mm Exhaust.
I own a 600T and the Spectre Pro will not fit in the top but does in the front, can no one tell me for definite that they have a 200mm working in the top?
What exactly is stopping it from fitting in to the top of the case, theres a 200mm fan there as standard with mounting holes identical to the spectre pro, is it a case of it hitting the outer edges of the case? A better setup for the top is 2 x 140mm fans anyway as it would be capable of shifting more air and could be plugged in to a fan controller to reduce noise
Just ordered two BitFenix Spectre PRO 200mm fans to replace my stock fans in my 650D. Was going to go for the CM MegaFlows, but they don't seem to shift as much air..
Anyways, was also going to remove the honeycomb mesh in front of the front intake as it seems to generate the most noise. Any suggestions for the ideal tool(s)? Anyone have pictures of their work? Also any suggestions for a flexible rubber coating(?) to go around the edge of the soon to be cut mesh so that there aren't any sharp edges left over?
Thanks![]()
