LED Lenser torches are good , especially in the dark!
So there is loads of pages but what's the actual brightest light you can buy then for under £100?
Or cottaging? Which I assume OP is going to the moors for.Deffo get a head torch. It will leave both hands free for digging.
A mag-light?
You could also use it to fend off the assailant.
While Lensers are good, they're not the brightest for the money and they're overpriced for what they offer as well.
The P7 isn't that bright (compared it to my Shadow and it's nowhere near as bright!, it was on par with my £15 Solarforce L2 350lumens though but not as strong in the middle) but it is a high quality torch. Then again anything from HK in that price range is just as good but offers brighter output and comes with more accessories usually, lanyards, spare o-rings, bezels and so on.
If it's your first light then the P7 does seem very bright. Only when you compare side by side do you see the difference!
Mag lights are great as weapons, but poo as torches
So long as you stay clear of Trustfire & Ultrafire, the emitters only seem to last a few months before going dim and the build quality is shocking.
This. Maybe sellotaping a decent LED torch onto an iron bar would give the best of both worlds..![]()
Indeed my Ultrafire C8 is still going on over a year old now AND Aod borrowed it and took it to Africa so the age old avoid Ultrafire statement doesn't apply all the time![]()
