upgrade or orm. both can be transferred/hardware upgradesSo which version do you need to be able to install many times on ONE computer. Like the old retail version of windows 7? I am really confused by the different versions.
Mainstream software quickly became graphical for a good reason - it was a better solution for a lot of mainstream uses. The same will happen with Metro style apps because they, too, are better solution for a lot of mainstream scenarios.
Microsoft won't get rid of WIMP interfaces just like they haven't ditched the command line. Having to go through a Metro style interface to get to the desktop is no different than having to launch the Start menu to get to the command line. It's trivial.
Times change, people will get used to it.
The market can't handle costs of full retail. All they are doing is bringing them self more in line with modern methods and expect it to continue to change untill we eventually get windows for a nominal or even free charge and content / windowsstore becomes teh cash cow.
Just look at apple and android.
it has. on the download versionIf times were changing it would be a download only and the option to make a bootable USB drive.
I never said that Microsoft will get rid of the WIMP interface completely. But if the applications I need are only available in Modern UI then that's what I'll have to use, just like command line fans ended up having to run graphical software. Obviously that's not something I'd be happy about.
at least 3GBVery nice then. It has partially moved on. What size of stick do they recommend? hope it's not a silly amount.
Nobody is going to release touch versions of Photoshop any time soon, believe me.
Am I right in thinking the upgrade editions are downloads from the Microsoft website and not a DVD? It's just I have a really pitiful download speed 0.5mb so it would take roughly 24 hours to download and simply not practical.
yep, it's a download. no dvd. u can pay to get a dvd i think it's extra £14.99 from MSAm I right in thinking the upgrade editions are downloads from the Microsoft website and not a DVD? It's just I have a really pitiful download speed 0.5mb so it would take roughly 24 hours to download and simply not practical.
that is total madness that is like but then if it is going to cut costs then i can see why my only problem would be i have a tendency to lose stuff so i would lose the serial straight away just hope they give you a recovery link to retrieve you key
