[TW]Fox;22964677 said:Worst 'I have access to an F10 M5' post ever. Read the manual its saved on Idrive.
Chaps
Quick question - My E46 has a iPhone 4 phone cradle which i no longer need. Is there something i can buy and put into place as its pretty ugly !!
Sam
You can buy a drink holder to go where the cradle was. Don't know the part number but it was around £30 when I bought it for mine 2 years ago.
It's not random options really. It's just got a very good spec and then the individual trim.I'm sure I've seen that very car or another manual E60 V8 in that colour on PH before. I think it was a dealers show car and it had the most random options ticked by them or BMW UK and it sat for sale for a long long time![]()
I'm now scared that you're having to run very high pressures in your tyres to not make the car feel unstable!
I can appreciate that you might have to put more pressure in than on the runflats but running at those pressures aren't they going to wear out very quickly. I'm want to get away from running runflats as they're so hard, replacing them with normal tyres but running them at very high pressures seems to be a bit odd.
I just don't want to spend £800 on tyres that I'm going to regret buying![]()
Thank you for your online enquiry dated October 11, 2012, with regard to the validity of your vehicles warranty, should you change the Run-flat tyres to standard ones.
All of our vehicles that use Run-flat technology have their suspension and braking components set up to accommodate Run-flat tyres. Should you decide to change to non Run-flats, it may alter the driving and handling characteristics of your vehicle. It is for this reason that this modification is not recommended by BMW as a manufacturer.
It is possible to have standard tyres fitted. You will additionally need to purchase either a spare wheel with jack and brace set or a mobility kit which can be ordered from the Parts Department of your nearest BMW Approved Dealership. The only way this would impact on your BMW UK Warranty is if any fault was caused by the change in tyre.
Once again, thank you for taking the time to contact us. Please do not hesitate to contact me if you have any further queries.
From my recent query to BMW Warranty ...
 http://www.camskill.co.uk/m61b0s22p...gle_F1_Asymmetric_2_-_255_35R18_94Y_XL_FP_TL_
£326.80 inc delivery
HEADRAT
I recently got 2 x 255/35/18 Goodyear F1A2's for £306 inc del.
Lovetyres.com
Buy them now, thank me later.
EDIT: Or not. They are now £174 and are out of stock. They were £149.99 before![]()
