Hate to say it but am I the only one thinking whats the big deal ?
People skydive everyday, he just did it from higher up ..... Even I could do that so fail to see why this is even news worthy.
Hydrogen may have provided 8% more lift but it would've also provided 100% more flammability.
However I wonder how it would burn/explode at 128K feet with such a rarefied atmosphere, would it even combust fully with that little oxygen?Ah just the person I was looking for, have you head of these guys http://www.halojumpers.com/en.php They do jumps from 30,000ft. One day I will do a jump with them!
Questions 1 and 2 (as I tried to explain to a friend), I think of it like a fishing bobber in a lake with a lead weight on it. Take the bobber to the bottom and release it, it will float to the surface of the water and bob there, moving up and down with the motion of the water. Now, disconnect the lead weight and the weight will drop to the lake bottom, but the bobber will float up just a little higher on top of the water. There it will hang out until eaten by a grue. Using this example demonstrates why the balloon appeared to inflate more as it gained altitude -- the "weight" of the atmosphere crushed it at ground level just as water would crush a sealed container if it went deep enough.
My question is, if said bobber is filled with helium it might float just a little higher in the water or possibly even float slightly above it (depending on weight and internal volume). If they had used hydrogen instead of helium in the balloon -- although much more hazardous -- how much (if any) additional altitude could have been gained?
Lowest deployment was an illegal jump, and was about 800ft off the ground![]()
Why the late deployment for the giggles or another reason?
Yes, he understood after I used that analogy. He couldn't understand why the altitude kept going up and down right before the jump.I'm not surprised your friend didn't understand that!
Isn't it something along the lines of: Helium is lighter than air so it floats. Once the density of the air gets so low the helium is no longer lighter so it stops getting higher.
Given that you wouldn't be in orbit per se, you could potentially be at something like 100miles up and still fall straight down?
I was just using hydrogen hypothetically. The thin material of the balloon, risk of static discharge at any altitude, and all the electronics involved would make that a really dumb idea. So the estimate is 8%, and would have brought the ceiling to almost 140,000 feet in this case. Yeah, not worth the risk for the extra altitude. I believe we're still in the stratosphere at this point, so hydrogen would still have buoyancy. But there is still "air" in the thermosphere. Would it be enough to support hydrogen with the additional weight attached? How much would volume make a difference?Well there is the explosiveness of itHowever I wonder how it would burn/explode at 128K feet with such a rarefied atmosphere, would it even combust fully with that little oxygen?
Our own moon is in freefall toward Earth right now, and the Earth is in freefall toward the Sun, and always has been. But centripetal force from the "ground speed" keeps it out where it is, just like how a spacecraft requires about 18,000-25,000 mph to remain aloft in orbit around Earth. Higher speed equals higher orbit.Given that you wouldn't be in orbit per se, you could potentially be at something like 100miles up and still fall straight down?
Here's the footage from the GoPro on his suit.
To anyone that is saying this was "just" a really high skydive.... yea.... sure.
