Hello guys, I am new to overclocker's forums and moreover new to computing.
So I bough this computer which is great works fine and I don't have any problems with it, but when I start playing some games, or render same videos it goes mad, like literally its so loud (I mean fans).
I am making youtube videos and I am using Blue Yeti microphone which is extremely sensitive and I put gain to lowest point that I can but the fan noise is still extremely annoying and microphone itself keep catching it.
So after a while I decided to check which one of these fans are so loud (My pc has 4)
So I put my computer on full load and saw that its not the psu fan, not case fan and not graphic card fan so it has to be CPU fan. So I slowed it down and yeah without it, it was so quite. And moreover no matter if this fan works load like jet, it still does not do its job cpu temperature jumps up to 80c and I really think thats because its bad cooler.
So here is some information about my computer.
System: Microsoft Windows 7 Ultimate (x64) Build 7600
Processor: 8 CORE AMD FX-8150
MAX TDP 124W
Socket AM3+ (942)
Motherboard: ASUS M5A78L-M/USB3 (AMD RS880 + SB750)
Memory: 16 GBytes
Hard Drive: Seagate ST2000DL001-9VT156 (1,907,729 MBytes (2000 GB))
Optical Drive: TSSTcorp CDDVDW SH-222BB (DVD+R DL)
Display: nVIDIA GeForce GTX 560 Ti (GF114-400)
HighDefinition Audio Controller
nVIDIA GF114 - High Definition Audio Controller
So could you give me advice on a good reliable and quite CPU Fan, because I looked internet and I found a lot of different ones, but I don't know which one will fit my computer.
I would really appreciate if someone could give a good choice of CPU coolers.
MAX TDP 124W
Socket AM3+ (942)
Memory: 16 GBytes
 I don't know where you live but if you have to pay to send cooler with bad pump back for RMA from UK it costs over £30 out of your pocket to get a replacement for a defective product.
   I don't know where you live but if you have to pay to send cooler with bad pump back for RMA from UK it costs over £30 out of your pocket to get a replacement for a defective product.  I recommend the Noctua D14 because of the current price, and how easy it is to install after you put the mounting bracket on. It's compatible with almost all sockets. Including AM3+. I have it and love it, very quiet and performs so well. It's a pleasure to install and would sort out your temp problems.
