- 26 Jan 2009
GraveYard, could it be down to your character, can you create another and try that?
tried that today mate and a hardcore char...
hardcore char didnt even load into a server come to think of it...
some people have been saying that running as administrator and running it in vista 32 bit compatibility mode can help, have you tried either ?
Have you tried it with upnp disabled? I had issues with certain games not liking it, once disabled though they worked fine.
no, will that help?
no, will that help?
no never worked, damn it.
just want to play...
now what happens is i join a server walk or run for about 30 secs to a min then it freezes and boots me back to char select screen.
some times it does crash with send error report but mainly a DC to char screen now...
Have you tried running it in Compatibility Mode?
(right-click the warz exe, hit properties, select 'Compatibility' tab, tick the 'Run this program in compatibility mode for' box and choose 'Windows XP (Service Pack 3)'.
Worth a shot if you haven't tried it already, as it has helped some people.
If you're getting booted back to the character selection screen, that's a whole different thing to the game crashing - you're getting disconnected from the server. That's either going to be caused by a file mismatch (unlikely) or your net connection, as already posted above, I would have suggested playing with the UPNP configuration. Sounds silly, but check your firewall and anti-virus as well just in case - you never know.
As for the game actually crashing, it's happened twice to me since the day one patch, before which it was random but I did receive it a lot more. If you're still getting that, tweak the graphics settings and take a look at any overclocks if you have any.
