AMD "Never Settle" 12.11 Driver - benchmarks
No issue here card stays at 300
thats 12.11 beta though going to try 12.10 yea flash shouldnt be making the card go right up to 3d clocks right ? well mine goes full tilt watching flash
the leaked beta was called AMD_Catalyst_12.11_Beta1_dotNET4 the official beta is AMD_Catalyst_12.11_Beta3_dotNET4
I remember it used to on old drivers 12.1 or something but not had it happen since. Using 12.11 here
Hmm, ive got the same problem. My idle clocks should be 300/150 but they are 500/1375. :(
No one else has this problem?
I wonder what could cause that.
Borked driver? Mine are always 300/150 but my mem clock is at what I overclock to permanantly and the core doesn't go below 500mhz.
Will disable all overclocking and try then, vanilla GHZ settings.
Don't know ive just installed and im at stock settings but the powerplay tables appear different, ie wrong. Either that or something else is causing it as other people said theres clocked down ok.
100% no issues with idle 2D clocks here, 300/150, applied overclock and shot up to 1325/1800, finished bench back to 300/150, removed OC still at 300/150.
Just hit a 2471 in Heaven, another 20mhz on the core and another 100mhz on the memory should see me into 2500 territory :D
