Anyone here got a Ragley Blue Pig? If so, what are they like? Just chopped in an Orange Crush for one based on Bike Radar reviews.
My mate recently got one from the CRC sale, and it's such an angry looking bike, love it!
Do you happen to know why there are no 2012 Ragley bikes? I could only find the 2011 range
Hi everyone, I'm after a bit of advice, my Norco has developed the dreaded yellow patches around the headset, I'll Post pics later as I'm at work, but I've contacted Evans Cycles who have allegedly contacted Norco and they've come back to me with a few options: 1: Replacement 2013 frame in a different colour but have said they cannot get a clear answer from Norco with a date and it could be as late as May!!! 2: £250 voucher or 3: Use the voucher to have it re spayed at Argos Cycles. What would you people do if you was in my situation, your help appreciated.
i want to service my fox vanilla 32's ... £100 seems a bit steep to send them to Mojo so I might do them myself.
so what do i need altogether?
Pedal On have the 32mm service kit for £21, is it just some Fox Fluid that ill need aswell?
also, is it a potchy job?
Hobbit said:You will find TFTuned and Mojo are very picky about when something needs replaced. I think with bascamp if a part will last for another year they will leave it. Saves a bit of cash.
this bike stuff is turning into a money sink!
My front wheel is bent, its the one that came with the bike and is a bit pony. Probably did the damage when i had my off and only noticed when fitting my new brakes.
What rims would you recommend for a 15 stoner who mainly does XC but will try to do anything else (ability and bike permitting) and wont buckle under my weight.
