im guessing i can use this for the £24.99 offer? did u receive a key?
and is it 32bit or 64bit?
Yeah it's for the £25 upgrade offer
When mine gave the option to buy something it just said "Windows 8 Pro" so I'm guessing it'll check your system and just offer up what's possible. So 64bit installed OS it'll just give you 64bit. 32bit (with a 64bit capable CPU) and I'd imagine it would offer both.Might want to bookmark the link page for buying Windows 8 tomorrow.
http://windows.microsoft.com/en-GB/windows/buy
All that'll be doing is offering up the Upgrade Assistant that I posted above.
Thanks
Will this be up at 12am or is release some time during the day?
Anyone know if an ISO will be available, or do we have to use the upgrade assistant?
Everything goes through the Upgrade Assistant! Compatibility check, purchase, download and either install or transfer to media (it'll either create an ISO for you or transfer it directly to a bootable USB drive).
Yeah same here couldnt see anywhere at first but it tells you to enter promo code just before you comfirm to buy, just after the page you select payment method. Mine is now burned on a Disk ready for install when ive moved stuff from other drive.
I got caught out with it being out today. Currently backing up to external HDD as I'm wiping and starting fresh.
How have you done that ? When I try to run the upgrade assistant I get this error : Internal error : error running compatability check. Check logs for details.
Just went straight through no problems
I may be some time.
