My fingers where sore as well. lol
Lovely m8 well done. Loving the purple. Can't wait to see the full system under water.!!!
Did you find it difficult to switch the pump speed when I tried the red dial
Snapped mines now set to 3, I'll have to give oc a call and see what can be done.
What do I need m8 to drain my system without cutting the tubing every time
I change the fluid?
Could you put up a basket for me
I purposely left the pipes to my dual bay res longer than need be so I could pull the res out the front and undo the compression fitting and empty the fluid into a bucket. I have ordered a tap and hopefully OcUK will have stock by the time my GPU blocks are here and I will attach that between the bottom rad and second GPU. Not sure if there is an easier way but this seems ok with only a tiny spill possible and away from all components.
PGI helped me with spec mate and I would start a new thread with what you are looking to do.
Good luck
