- 22 Mar 2009
£10?
yes with PROM code enter!
£10?
Sub 10-second start and shutdown. Nice Windows explorer, new task manager are just a handful of things.![]()
On the upgrade assistant checkout there's a box which you can tick, WIndows Dvd.
Does this mean I will get windows 8 pro upgrade on disc as well ?
Or is it worth just getting the Boxed version ?
D'oh
Missed out on all the fun.
The Windows website has been taking off "coming soon"
and the dropbox link with the Windows 8 Upgrade Assistant is showing 404.
I've put it in my Dropbox public folder here:
https://dl.dropbox.com/u/4353235/Windows8-UpgradeAssistant.exe
anyone ?
I wouldn't just delete it no.
Check in the add / remove windows features to see if youve got iis selected as an active feature.
Perhaps iis was active in your old os, so w8 upgrade did the same, it's not normally active by default.
I take it you don't normally use your pc as a web server, or you installed web development software?
Either that or you got anything involving web sharing, like a printer perhaps?
£10?
I removed my link to Dropbox since someone posted an official link a few pages back![]()
was set on getting this but I'm unsure if steam will run fine and also fm13 which I play and having just bought fm13 I don't want to throw £30 down the drain if its incompaitable with w8.
Anyone got steam and fm13 working?
,off to test ME3 MP via Origin now.Where that from then, with a new pc purchase?
Now I have reinstalled win7, how would I go about getting my w8 update again?
Steam works perfect on my release preview & FM12 worked fine also so if FM13 doesn't I'd be surprised, Either way if it doesn't just set compatibly mode!
Oh yeah hurry up & dispatch my copy OcUK![]()
