go to Personalisation then click automatic then choose automatic.
What's all of this nonsense about not having a close or reduce button for apps
and why no easy to reach shutdown/restart button.
Guys what Antivirus works well on windows 8 ?
is one needed as windows does have one ?
also when windows update assistant checked my laptop before installation it listed a compaitability issue with secure boot saying I will not be able to use this feature? , is this a big problem?
thanks
People are actually buying this to replace Win7 on their desktop PC's![]()
no issues here with the arrow keysOh my... I think I found a problem. Typing some stuff, then tried to use the left arrow on the keyboard to change the previous word. It doesn't work. Checked to see if the other arrow keys are fine, and they worked. Same problem occurs with the onscreen keyboard. Keyboard works fine with the 7 partition.
Well this is going to be a problem when typing up essays...
Yes got a problem with that?..better security,faster bootup and shutdown,loads of software including free stuff in Store,better battery life on laptops etc....very stable and no driver issues,can run it as desktop or tablet based,very low price to buy so why wouldn't you?...
I just got to upgrade my fairly new laptop now from 7 to 8 for £14.99(got my promo code already).
Not got a problem with it, just a bit surprised
It's a tablet OS isn't it?
Should I be installing my mobo drivers or just stick with the Win8 ones
http://www.gigabyte.com/products/product-page.aspx?pid=3765#driver
HEADRAT
No problems in Device Manager, but didn't know if I should be installing things like USB3, Intel INF/RST drivers etc?
