you'll have to let us know what they are like after a few rides, i posted a link a few pages back but got no response. They look immense is the unit big? can you post a pic?
You're not going to damage the shifter and you should change the chain when you get a new cassette anyway. I don't see a problem.
I responded when you first posted.
No the unit is nice and small, easy small and light enough to helmet mount as well.
Not my pic but you get the idea.
*snip*
ichyballs, how do you find the weight of the batty on the back of the helmet? does it balance ok with the lights up front?
Those 5.10 Barrons look good. they have the Stealth soles so no probs with stickyness. what type of riding you do?
That light is not small, these are small!
edit: havent used the barrons myself but have a pair of 5.10 monster shoes. awesome!
My Xt cranks catched so the bike shop filled of the tabs from the small ring, just means i cannot go back to 3 ring setup which i wont anywayFitted the Superstar plasma chain guide, nano through pedals and e thirteen g ring yesterday. Also fitted my old Superstar wheels which are surprisingly lighter than the DT swiss AM1800 that were on before. Had to use a medium spacer on the drive side part of the bottom bracket as the inner chain ring lugs were catching the guide plate and I'm not defacing an XT crank for a superstar guide!
The mud guard is just a standard white mucky nutz guard, it does the job and only weighs a few grams: http://www.muckynutz.com/index.php?route=product/category&path=49_46
Thanks for the link, Will look to get one ordered...![]()
