You can't really go wrong with either card, I'd personally give the wind force another try if you're after silence. Gigabyte have never let me down when it comes to sorting faulty products out so you have nothing to worry about.
Maybe this is acceptable with AMD cards?
What do you mean?
Even though it is your card in this instance, I just wanted to add that my 7870 is now having issues with Skyrim as well. It's potentially down to the 12.10 drivers, but I'm not 100% as it's been a few releases since I last played.
Just throwing this in, incase you get your new card and Skyrim is still acting up. I am getting the same issues you describe, sky flickers badly, distant terrain flickers, but it seems to be fine inside. So don't panic if you load up skyrim on the new card and are greeted with artifacts again.
I also seem to be having the same issue with Skyrim since updating to 12.10 on my 7870. Flashing sky, I initially thought I'd messed up myself because I'd been editing a mod in creation kit and accidentally deleted something which I thought might have caused it but after disabling the mod, still had issues with flashing sky.
I'm running at stock speeds too and the card has been fine before.
Possibly just 12.10?
I know you hate AMD greg but it cant be normal lol
Surely can't be that normal... Have you seen the skyrim die hard nerds? If this was a normal issue, they'd be going on a keyboard warrior rampage![]()
