- 27 Jan 2009
- Oxfordshire
I think in this case it was single use, I tried it just now and it said it had already been redeemd
I don't know why anyone would want to cheat by maxing all the skills etc. It would destroy all the time and effort you have just put in to get the skills and stats you had. Completely ruins the game and after a while you would realise there no point in even playing any more as there is nothing to work toward...
Without using the bugged terrain on the ramp I doubt its possible for any class to solo him... unless you use the Bee and Conference Call.
you wouldn't say that if you were trying to kill Hyperious last night !!!
Zero kills everything easily now, but he cant kill those side bosses, i killed three of Hyperious robot consorts last night and that was a nightmare; you have to crouch down on the left hand side of the entrance, i didn't die i just quit the game after killing 3, i ran out of AMMO
I would have died anyway, because to get the 4th robot would have meant that i would have had to exit cover and take him on head on... no way!
he will not even be scatched by your most powerful RL, you have to kill his minions first, they die ok but drain your ammo
he will die easily if i had someone with me
I thought you had all your skills maxed and hacked gear? How can you need help![]()
unfortunately the cheats/hacks dont work with the latest BL and it isn't worth searching for them or you'll get that malware virus.
Did anyone get bored with this game? I've got to a certain point, stopped and have not bothered to go back....
i think i was doomed a long time ago
take a look at this, this is deffo someone that has traded/ cheated
he uses a bee shield... where do i get this from ?
More likely someone who has farmed far too damn much. Getting hold of the Legendary Berserker class mod seems all but impossible with the pathetic spawn rate of Vermivorous though ><
I did get bored after getting my commando to lv50, but then started a new character and started enjoying it again. I keep getting a bit bored but then getting the urge to play it again.
I can't wait for more dlc though. Its always far better when you play through the first time.
Reloading really peeves me off in this game, especially when u die and switch weapon on your countdown only to find it starts reloading. Rage inducing !!
I'm level 30 using the sniper/assasin guy and tbh struggling. Don't think i've skilled him up well, bit of a mish mash toon.
If any of you guys are about I'm about to have at it with Terramorphous![]()
