- 5 Jul 2007
- London
Cause he's black
lol at Maldonado outqualifying Senna by 1.1 seconds
sarcasm detector malfunction
Cause he's black
5.20 Replacing engine parts :
The parts in lists A and B below may be changed without incurring a penalty under Article 28.4 of the F1 Sporting Regulations. If changing any of these parts involves breaking a seal this may be done but must carried out under FIA supervision. The parts in List B may only be replaced by identical homologated parts in accordance with Appendix 4 of the F1 Sporting Regulations.
List A
- Clutch.
- Clutch basket.
- Hydraulic pumps.
- Engine electronic boxes (ECU's, power modules, control boxes).
- Fuel filters.
- Fuel pumps.
- Oil filters.
- Oil tank systems.
- Pneumatic bottles, regulators, pumps and pipes for valve actuation.
- Exhaust systems.
- Supports and brackets related to the auxiliaries, mentioned above.
- Screws, nuts, dowels or washers related to the auxiliaries, mentioned above.
- Cables, tubes or hoses related to the auxiliaries, mentioned above.
- Oil or air seals related to the auxiliaries, mentioned above.
- Spark plugs.
List B
- Throttle system (including but not limited to throttle device, linkage, actuator, hydraulics).
- Intake system external to cylinder head (including but not limited to trumpets, trumpet tray, air box, air filter).
- Ignition coils.
- Injection system.
- Alternators.
- Oil scavenging pumps.
- Oil supply pumps.
- Oil air separators.
- Water pumps.
- Electric and electronic sensors.
Engine bits you can change:
Ted Kravitz @tedkravitz
Still on the Vettel trail - He just emerged from stewards smiling along with Renault and Red Bull engineers.. More soon
So if Vettels gets away with this, then everyone just use the excuse they gave and run less fuel next time?
Hit vimto.....please![]()
@adamcooperf1
#F1 Vettel investigation ongoing - Christian Horner and more Renault guys have now gone to race control to see FIA
#F1 Unusual for a team principal to become involved in such matters which can only mean it's getting serious for Vettel...
Andrew Benson @andrewbensonf1
RT @5LiveF1 Christian Horner tells BBC's Gary Anderson that there was a problem with the fuel system
That Horner remark v interesting - I was told by insiders a while ago unconfirmed rumours that Vettel did not have enough fuel
Hmm...
How would that help, I'm sure they would calculate fuel levels without going off to see if it was to get round low fuel...After Hamilton ran out of fuel I asked if he'd have been better off 'crashing' into a gravel trap, if he'd done so he would have been ok and not stuck at the back of the grid.
Lee Stevenson @leestevo1
“@stujones55: Waiting......... https://twitter.com/stujones55/status/264781801300574209/photo/1 And waiting....
