I found the Commando easier in the earlier levels than Maya. Never played Gunzerker but I'd imagine the turrets would help if you're struggling with it.
In the later levels though the turret doesn't really help all that much. It is very useful as a decoy though and also can **** enemies if you use the left tree. I actually stopped using the turret after lv20 as I wanted to raise my badass points and the turret does steal a lot of kills early on.
It's useful to drop if you think you're close to going down as it will often get you a secondwind. Plus Axton has a skill that gives you something like 60% gun damage in ffyl which was a great help. Seems much harder to get second winds with maya.
