I'm just adding my own little sum up in two days use here, hope you don't mind.
I have not had a good look around yet so not sure on prices oh big Apps but the obvious weakness is the lack of some big names, not that minding to much yet, theirs a lot packed in it from the box, Full Office is the obvious one which is pretty much a full desktop version, if you want to use that much then you WILL need the touch cover.
But, theirs so much right with it I couldn't write it all down, esp if you already have a Win8 pc, Xbox and have been using their Skydrive account.
Just about the screen yes it not the same res, and it shows, but you are looking for it it, as they use subpixels between and the colour and contrast is the best I think so far, media consumers will be very happy with this, as well as photographers. Also, the usb stick, it really works, dragging dropping movies and music into folders via a proper desktop and Windows explorer, again the cover keyboard trackpad would be preferred for this, but touch options have been made, same for the SD card, with my 32gb one working fine, just as well as you might have read about the 32gb versions actually only having 16gb of available memory, as MS state, but people didn't read, mostly due to just how much is in it out of the box, office, explorer etc. If you want the space you can delete them.
Internet Explorer 10, ya have to really forget everything you think you know about past explorers, this is fast, renders text Very well, no weird formatting either.
Also, iPlayer and YouTube works as full browsers, though with iPlayer you have to press and hold to get the player to play, but not a shabby implementation at all.
Though, the build quality, it feels fantastic, utter quality, and looks it, the kick stand might be thin but you have full confidence in it even if dropped. However it is big, in the widescreen, this is NOT a tablet for your pocket, or for portrait mode for that matter, still with a comfortable weight.
Everything runs smooth for me with some updates for each MS app being swift, and I expect will only be optimised even further with time and real world feedback.
Overall, you cant help but think this is a PROPER tablet, I know it sounds stupid, and it does deffo have some problems, but it really makes Droid feel cheaper in some way, and iOS toy like.
Ohh yea, Windows Desktop keyboard short cuts work, for example typing this mini review on it, I want to copy it all in case the ****er doesn't post right, do what you would usually do, ctrl +a (select all) then ctrl +c (copy) works just the same.
Just to add to this, I'm really thinking I should have ordered the cover/ keyboard now for the ease of navigating the desktop side of things.
