Using my old injector settings but only enable the sharpening settings + colour tweaker feels like I'm playing a new game!
Makes such a difference!
Yeah that's what I was thinking at the time, I'm going to try it again later and test a few different servers/ maps etc.doesnt touch your controls
i can only guess something else was doing that all it does it alter colour settings
A few niggles with BF3 I'm having:
Jesus christ the server browser is terrible.
It only shows 30 servers and then you have to manually scroll down the page to load more...I have never seen this in any other game, who the hell thought that would be clever? especially as those first 30 aren't gauranteed to be populated and you have to scroll before you can sort them.
Even then, it's pot luck what servers it feels like showing you, each refresh will bring up a different set even after scrolling as well as listing duplicates.
I also have to try 3 times to connect to each server, first time it loads up the level and then CTD's, the second time it starts then game then disappears, the 3rd time if i'm lucky it will connect properly, this is every damn time i want to join a server.
your old ones were good too.
I just expereinced the most terrible micro stutter in BF3, felt like treacle.
I have just down graded from the 310.33 drivers, see if that helps...![]()
You do know you that you can filter the servers right?
Not had one problem with the server list, learn to use it before you moan about it?
