- 13 Jul 2009
- Cambs
*snip*
Ah looks good!
*snip*
If I had sponges etc on the original Vanilla server, are they gone forever, like my build LOL?
is there a limited amount of distance you can pipe oil? found a large depot near me but dont wanna set it up if its useless haha
I've found myself quite often to see skelies and mobs in "daylight" but if you recon then it goes dark. Not sure if it's a lag thing, but i did notice that before the refresh of the mining world.Is it daytime on the mining world all the time?
Can anyone recommend some useful addons / mods that I can use with the vanilla server??
Ta
If you haven't played on the Official OCUK Minecraft server before you will need to get yourself whitelisted!
http://linktart.co.uk/how-to-join/
Sign up to LinkTart.co.uk then create a thread requesting to be whitelisted, you will be asked some questions relating to the server rules, then if you get them al lcorrect you can join the server by using the IP provided in the link above
Full details are in the above link! See you on the server![]()
I don't know if Maxi/saf are allowing the old donations to be carried over to the new vanilla server.
