Game Explorer
u know what I meant
I didn't actually.
Game Explorer
u know what I meant
Whats Game Explorer ?
Yeah you will* get the option to create an .ISO file once the files have been downloaded, and you can use it for a fresh install.
Once you have the key(which you get immediately after purchase and before the download begins), you can use it for fresh installs or upgrade from any compatible windows install through the upgrade tool. AFAIK It only checks your current license at the initial purchase stage.
NB: in the email they send with your Product Key, there' a link to re-download the files(through the upgrade assistant).
*Some people don't get the option to create a .ISO, i think this is only if upgrading from WinXP but i'm not sure.
If you don't get the option to create an ISO, you can create a bootable disc from the downloaded files instead:
(http://www.pagestart.com/win8esdtodvd11041202.html)
Windows
Thank you for registering for our free Windows 8 Media Center Pack offer! **
Here’s your free Windows 8 Media Center Pack product key:
no need to install xp. just as long as u got a valid physical license if u get what I meanWhats the cheapest route to get windows 8 and where from.
I have old copies of xp so would I qualify for the upgrade option? Do I need to have xp installed for will I just be able to stick disk in for it to check?
Matt
I noticed this media pack offer now sends the key
Still haven't got mine. It's been over 4 days now.
Right have downloaded it, seems to have created a shortcut on the desktop, what do I need to do now?
