** NEW CORSAIR LCS OFFERINGS AT OCUK **
  • Thread starter Thread starter rjk
  • Start date Start date
I will probably pick up the h100i within a few weeks.
I was looking to upgrade to a h100 soon/LCS kit. However with the h100i coming out which includes corsair link and 2 x SP120 performance fans for only £5 more than the h100, how could I delay any longer and say no?
Hmm there's only two fan inputs on the block compared to the h100 that has four. I'm using four vipers on my h100 all plugged into the h100 cpu block, but with the h100i I guess i'd have to stick two into the mobo.
Suppose could use two of these in each socket on the block for push pull.
Maybe use 4-way Gelid PWM splitter like first pic instead of the Akasa mess of worms with 5 leads from each pin in input socket to break off.
images
Power load is from PWM molex. ;)
(First post at OCUK forums - hi to everyone)
Thanks for the reminder to watch Linus's video. He's probably one of the first unboxing the H100. Though he missed a few things that I would have liked to hear more about.
(1) Software configurable led lighting on the waterblock of a colour of your choice.
(2) How the stock fans compare to the SP120s. I will be keeping my SP120s because I cannot give up my beloved red rims. Though I would like to know whether the stock fans are more akin to the high performance edition or the quiet edition. What are the rpms, airflow and noise levels for the stock fans?
(3) The fact that there appear to only two fan leads as opposed to four. I'm rather puzzled by this because, even though, I only use two in push exhaust configuration (with other fans due to go into the lamptron fc5v2) I imagine others will want to use push-pull. How are they going to do that? Correction: ignore this - this is wrong - it has four.
(4) A quick demo of the corsair link software working with the cooler.
TastyPCTV - if you're reading this - you should cover the above in addition to everything else for a kick ass review! ;)
Personally I love the rubber tubing, the new waterblock compact glossy design, the marginally larger radiator and the new stock fans (though why oh why did they make them grey when everything else is black).
I just finished my first pc build ever recently and had bought and fitted an H100 as part of that. However it came with one screwhole too big so amazon have agreed to take it back. So I've preordered the H100i from OCUK and when it arrives I'll send the old one back to amazon. Luckily I have a year to send it back to amazon since it's faulty. Lol. You've got to love warranty from the retailer as well as the manufacturer. The customer can't lose!
Anyway, hopefully, I'll see the H100i arrive in the next week or two from OCUK and I'll report back as to how much of an improvement it provides. My current i7-3770k at stock clocks (as I'm new to overclocking) stays at 15-23C at idle. Need to test with Prime95 for load temps but I expect it'll do just fine.
My primary problem with the new build is not the CPU or the MB temps which stay at around 20C and 35C at idle. It's the two asus matrix hd platinum cards that remain at around 55C at idle. Need to figure out what's going on there. I wish there was as easy a solution as a sealed liquid loop to integrate into gpus with large radiator surface area.
Update: Point (3) above is wrong. It has four. My mistake.
Did you watch the video? at around the 4 minute mark you can clearly see him plugging two y splitters into the unit to power four fans.
You're right. My mistake. I did watch it but I think somehow I got thrown off firstly by the fact that he was talking about corsair link while plugging the fans in and secondly by earlier posts on this thread stating there were only two which I assumed they'd verified. Combine that with severe sleep deprivation this morning due to staying up far too late playing with airflow and cooling options and you have a recipe for error. Thanks.
Looks like my cooler of choice when I finally upgrade (probably to Haswell).
MichaelM said:
Any update on the expected delivery time and warranty length on the H100i?
I see the H100i has just came into stock,so if you order on Thursday, you should get the H100i on Friday. Warranty should be 5 years.
CorsairGeorge said:
We have recreated that noise in the lab, it only happens when the fans are at extraordinarily low RPM on the built-in fan controller. For a short term fix, you can correct this by manually raising the minimum fan speed in Corsair Link.
It can likely be corrected with a firmware and software fix. We're working on a new firmware now and will release it when complete, should be no more than a week or so.
Sorry for any stress this caused anybody. Pretty embarrassing to have a noise issue after spending a year updating a product that already had a noise issue at one point.
Source
Worth watching this video all the way through.
I preordered mine. It shipped today. Will arrive tomorrow. Can't wait. I'm at work right now so can't really watch the noise video right now but reading that last comment I'm definitely slightly concerned. Hope it isn't too bad. Though I'll be using the two SP120 fans that I'm currently using with the older models. Also can't wait to use the configurable led - hope it has red as an option!
When you get home and watch the video, you'll see it has RGB tabels, so you can pick any colour :)
Now we just need a review as to how well it cools the CPU :)
The guy in the video seems to think that it's the fans and not the pump this time. In the vide0 he drops the fans to the 'quiet' setting and the noise returns. Speeding up the fans stops the noise. It could be that because the fans that come with the H100i are 2700rpm that they don't like being run down to 700rpm.
I currently have 2 SP120 Performance fans running between 7-800rpm and they don't make this noise.
I suppose it's plausible that the stock fans have been engineered to price rather than engineered correctly.
Oh and the LED is RGB so whatever colour you want :)
Thanks guys. Once I've assembled it I'll report back on how much better or worse it fares compared to H100. And also what noise levels are like with two SP120 Quiet Editions. As well as pics inside the case. Super happy about being able to configure the colour. From the video screenshot it looks like it's a fairly deep and bright colour which is great. It'll go with my black and red theme. I really didn't like the appearance of the old waterblock. It just looked cheap. Love the new one.
Just took delivery of a H80i. The quality of packaging is always a pleasure with Corsair products but that soon wore off when I noticed considerably bent fins on both sides and only 4 of the 8 washer for mounting the fans.
Not huge issues really but how can a simply item count and obvious visual damage happen with such an experienced company that has well packaged items :confused:
Well the manual indicates 8x long screws and 8x metal washers, there is also a diagram showing them all with a square radiator. Did the H80 come with a single fan for two of them like the H80i?
