SABERTOOTH Z77 BIOS 1708
1.Improve system stability.
2.Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Hello friends, please, to update the bios by ez flash I need to rename the bios? By downloading the site, I get the file with, .cap, only just put it on the flash drive formatted in FAT32 and update the ez flash? Thanks.
there are so many variables you can't really compare one persons without the fans to another persons with the fans like that. Things like room temp, case design, fan speed, room airflow, other hardware, coolers, system load, previous system load etc etc all make a difference.
Simply put the bios .CAP file on a FAT formatted usb stick. Do not rename the file and load it from EZ within the Bios EUFI.
I just re built my system with this board and an i5 3570K and so far I love it! Going to update bios to the new 1708 version soon.
Onboard fans are a bit whiny tho aren't they! Even turned all the way down
Latest BIOS has a renaming file which does it automatically once unzipped and moved, then run. Used it and then flashed using the included flash tool from within the BIOS, no issues to report. Like you say no need but I wanted to try this renaming tool out! lol
The onboard fans are a waste of time, not used them since the board was new and I've had no problems.
Thanks friends.
I was up till about 5:30 this morning twatting around with it & I'm running out of ideas.
Any help or advice would be appreciated.
Many Thanks
Aran
I'll start first with a pic of my board
