May be a silly question teledude but does the kernel on that rom allow overclocking?
When I plug in to USB, can I just dump stuff in the "Movies" folder and expect it to work?
Think I need to find better looking widgets. Using the AccuWeather one for clock/weather but it takes up half the screen.
Where do you all buy your OTG cables?
looks like the N7105 LTE models just got the multitasking update from Samsung officially, I've looked at it but can anyone tell me what the EDIT button does? You can drag applications into the area after you click edit, but not sure what happens?
