Hey, if it makes you feel any better - I've read over on BT's forum plenty of horror stories. The most common one is a contractor comes out and says "I don't have the keys to the cab" he walks away and then you have to rebook!!![]()
I've read similar. You'd think they'd know what would be needed beforehand, e.g. it's telegraph poles in the street so a new wire from it is required.
I'm dreading my appointment. I guess it depends upon whether you get a nice or grumpy guy who just can't be bothered. I'd like the master socket on the side on the first floor but that might be pushing my luck.
Does it have to be BT (openreach) who fit new lines, regardless of who you choose? Would have thought so.
(8.8.8.8 and 8.8.4.4) quite often in the last couple of weeks or so they've been extremely laggy or failing some lookups and 1-2 seemed to have some degree of "poisoning" (resolving to ad/malware sites on some common sites - 110% sure this isn't a local issue to my network).
