Are these good cards? Three year warranty.. NO Voltage Lock?
WIN WIN Surely?
I really like mine. Dual bios, voltage unlocked, good warranty, and they tend to be good clockers.
Mine can do 1175/1725 at stock volts (1.74v) and others can do even more. I think LtMatt has one that can do 1200+/1800+.
Yeah they must be better than average clocks as stock 7970 is 925 core and these are stock 1010 core.
Love mine, cheap and clocks better than some of the £400+ 7970 fancy cards. After selling the games mine worked out at £270. (kept sleeping dogs for myself)
Can go up to 1250 core 1900 memory. Will go higher but fan noise and temps become a problem. Can run 1125/1719 at stock voltage of 1.112. Can run Ghz edition speed of 1150 with a 2 notch voltage increase to 1.125.
Can run memory up to around 1725 before i even need to start increasing the voltage on it. With a voltage bump on the memory i can run stable @ 1875 24/7. I don't use it that fast though, its serious overkill. 1719 @ stock volts provides 330gb of bandwidth which is golden.
I know several people that have bought this card, the worst clocker did 1170 which was kissenger.
Your mileage may vary though.
