SkodaMart
SkodaMart
Have you tried uninstalling the Razer drivers and using the default Windows ones?
if its taking a while hopefully its fixing a lot of errors / bad sectors
fingers crossed it all works![]()
jeez I'm on part 5 of this and I've got miles to go haha!Have you tried uninstalling the Razer drivers and using the default Windows ones?
haha cant believe was something that simple ^^
glad its all fixed anyway now you can get back to your gaming
type
sfc /scannow
wasnt it the razer stuff causing the BSOD? chances are that faulty process had something to do with it and should go away with the mice problems. if it dosent post the .dmp file up next time it blue screens and ill take a good look into it
Ah well, thanks for the help guys! I'll report back if the problem persists!
Thank God for system restore - first time it has been really useful.
why would you need to sys restore?
