What settings are you using in BF3?
Everything maxed.
Motion blur off
FOV 70
Cards 1.13v 1050/1550 max temp I've seem 76C
fans at 55% until 80C then set to 75% (never gone to 75% yet)
I take it these temps are good?
Everything maxed.
Motion blur off
FOV 70
Everything maxed.
Motion blur off
FOV 70
Try this (you really won't notice any difference apart from increased frames!):
2xMSAA
SBAO (I found HBAO kills everything for no benefit)
Motion Blur off
Vsync off (unless you're on 60hz, in which case use a frame limiter)
Your cards have a low stock voltage, I'm stock at 1.175v 1010/1375.
2xMSAA
Motion Blur off
You sure that's your stock voltage? My stock voltage is 1.031 and I Overclocked 1100/1500 @1.131vYou sure that's your stock voltage? My stock voltage is 1.031 and I Overclocked 1100/1500 @1.131v
Yep, tbh I've had 6 7970's this year, every one of them has had a stock voltage of 1.175v
Powercolour ref 7970 - Sold for GTX670
MSI 7970 Lightning - Died
MSI 7970 OC - DSR'd
MSI 7970 Lightning - RMA replacement, sold
MSI 7970 OC - in use
As for the stuttering try changing the "Hardware Polling Period" in Afterburner from 1000ms to something higher, worked for me on both my GTX 680 & 7970.
What exactly does the Hardware Polling Period do? Is it just how often the monitor stats refresh?
Just going to see if I can find a solution to this stutter in FC3 with CF 7970's.
How do you check or change this Hardware Polling Period? Will give this a try amongst other things. Bf3 with a couple of 7970's in Eyefinity runs like a steaming pile for me.
