We'll have to invent new speeds for 3D holographic porn, the wankobyte.
Hydrogen Powered Cars.
Any reason you think thats at all likely in the next 13 years?
EU is backing electric battery not hydrogen.
Battery is far ahead in the roll out compared to hydrogen.
We have no infastructure to either produce or transport said hydrogen needed.
Predict the technology in 2025
So how will gaming work, is it all done via streaming like quake live?Smartphones will replace laptops and desktops for most people. This will be the setup for most people.
Anything is likely, If it were to happen then it would be free/pennies to run!
Hold on i need to charge my electric car i went for a 8 mile drive![]()
it wont happen, not a chance. we don't have the infrastructure to produce and transport that quantity of hydrogen and to build that infrastructure would take more than 13 years.
However fast charging exists today. EV cars that do 300miles rated and 260miles actual, exist today.
Prototype batteries that store 5 times lithium iron exist to day and should be in mass production in next 5-8 years, if the tests continue to go well.
There is just no backing for hydrogen, hydrogen makes no sense when you look at it.
All right, perhaps not 2025, but Hydrogen is still a good place to be...surely?
Still waiting for my Robot Butler that Tomorrow's World promised me back in the 80s.
iPhone 20
It will work in small steps i think. With undiscovered tech to be learned.
For example, we could have high tech energy converters for movement (phone), plus solar, plus wireless - thus making the most of the environment.
Disadvantages
* Lower efficiency, waste heat - The main disadvantages of inductive charging are its lower efficiency and increased resistive heating in comparison to direct contact. Implementations using lower frequencies or older drive technologies charge more slowly and generate heat within most portable electronics.
*More costly - Inductive charging also requires drive electronics and coils in both device and charger, increasing the complexity and cost of manufacturing.[1][2]
*Slower charging - due to the lower efficiency, devices can take longer to charge when supplied power is equal.
*Inconvenience - When a mobile device is connected to a cable, it can be freely moved around and operated while charging. In some implementations of inductive charging (such as the Qi standard), the mobile device must be left on a pad, and thus can't be moved around or easily operated while charging.
If we can download and print sex robots by then, I will be sore.
