MSI GTX 670 or HIS 7970
If I were you I would go for the 7970. However, I don't think you'll be able to go CrossFire without a CPU upgrade - it will bottleneck. You should be able to run a single 7970 though.
Had a change of heart, can't justify paying the extra if the 7950s can overclock to speeds equal to the 7970>
Is it really worth paying the extra for the 7970 guys?
uksoldierboy said:
cheers nelly, looking at some reviews of it now, hope it's not voltage locked.
They are in a sense >> http://forums.overclockers.co.uk/showthread.php?t=18465466
Looks like you have to enable 'Force constant voltage' to enable voltage decrease/increase in MSI Afterburner, but that breaks powerplay i.e. voltages won't drop in desktop.
I have a Gigabyte 7950 WF3, from a very new batch, it's as above, but locked at 1.25v, I switched to F42 bios off the Gigabyte website, and it's unlocked - the current batches from OcUK should be fine.
If your running Crossfire, probally better to get the HIS IceQ's, should clock quite abit, also they blow air directly outside the case, so should keep temps nice.
tommybhoy said:
Nope.
It's not voltage locked.
Is that definitly right then? No need to use 'Force Constant Voltage' in MSI Afterburner, like ViRuS2k mentioned, breaking power saving features?
Why would you need to do that? and where did ViRuS2k say that? :)
Might have to send these 2 cards back as i cant for the bloody life of me get the voltage to unlock.
I can get the slider to unlock and extend the overdrive limits, default is in msi afterburner : 975 ? is that not correct ? as msi shows default under hardware monitoring as : 0.949v
anyway what ever i select in the voltage slider and apply : does nothing still shows 3d clocks as : 1.056v
This is a none ref card does anyone else have this card is it locked ????
i think i have tryed everything lol wont budge....
also idle voltages seem to be fluctuating between the 2 cards at idle : 1 card is : 0.949v and never changes but the other one changes between 0.806v and 0.949v ??? shouldnt it be constantly the same as the other card ?
also i have noticed that a fan on one of my cards completely shuts off lol
seems these cards are more or issues compaired to the 69xxx series i had before.
i hope i have not picked the wrong cards.
Which is normal, in any case i think thats why he did it. (despite the fact that he did not need to)
He also has 7950 BE's, 'I think' which are voltage locked.
I think you need to ask him to clarify a few things :)
