Permabanned
- 3 Jul 2008
- My fabulous ship
Project: Noob (with big ideas)
So I just got my corsair 600t so I think it's time I started posting what the project is about.
I've never liquid cooled a PC before, I've built some from scratch, but never liquid cooled so I think it's about time I tried.
Please note that this is going to be a long lasting project and that I will be buying about £500 of goods per month so it will take a good few months before everything is purchased.
Research:
RAM: bit-tech
Fan round up 1: toms hardware
Fan round up 2: Xbit 140mm
Fan round up 3: Xbit 120mm
Fan round up 3: Hardware.fr
comparison,
difference between pwm/non-pwm fans
Current kit I'm getting:
Miscellaneous Parts
IKEA Table (£46.92) Purchased
chair (£69) Purchased
grommet drill bits (£8) Purchased
a toolbox (£19) Purchased
desk hub (9.23) Purchased
metal cutting tools (£71) Purchased
Peripherals
UK Filco Ninja Majestouch-2 (£95) Purchased
104PBT white side printed keycaps for Keyboard, Filco,Cherry (£54 with delivery) Purchased
G600 MMO Gaming Mouse (£69) Purchased
mouse pad (£2) Purchased
Astro A30 AUDIO SYSTEM (£169) Purchased
Components
Case: corsair 600t (£139.99) purchased
side panel (£78) (competitor site) purchased
motherboard: asus rampage iv (£379.99) purchased
psu: corsair ax1200i digital atx (£249.95) purchased
cpu: inter core i7 (£259.99) purchased
ram: x2 corsair vengeance red 32gb (4x8gb) ddr3 pc3-14900c10 1866mhz (£299.99) purchased
ssd: samsung 120gb ssd 840 evo (£84.95) purchased
gpu: x3 gigabyte geforce gtx 780 3072mb
watercooling components
radiators:
Fans: x9 Corsair Fan, SP120 PWM High Pressure Edition (£25.99) Purchased
Pump: XSPC D5 Vario (Body + Screwring) (£56.99) Purchased
Reservoir + base: EK-D5 X-RES 140 CSQ - Acetal+Nickel (£59.99) Purchased
CPU Block: EK Water Blocks EK-Supremacy - Acetal+Nickel (£51.98) Purchased
mosfet: EK Water Blocks EK-FB KIT RE4 - Acetal+Nickel CSQ (£94.98) Purchased
RAM Block: X2 EK Water Blocks EK-RAM Monarch X4 - Acetal+Nickel CSQ (£34.99) Purchased
RAM Connectors: EK Water Blocks EK-RAM Monarch Module - Black (2pcs) (£19.99)Purchased
Tubing: XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear (£6.49) Purchased
GPU Block: X3 EK Water Blocks FC Titan SE GPU Water Block - Acetal+Nickel
Connectors:
Coolant:
Current Total: £3088.88
Note: This article shows using nothing but quick disconnects gives very little flow interruption
I'll do a post for each stage with pictures of progress and any troubles I run into.
below are reserved posts which I will update until the stage is complete, Q&A can then be followed after it
Research:
RAM: bit-tech
comparison,
Miscellaneous Parts
Peripherals
Components
radiators:
Connectors:
QD3 Female Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) *Black* (£9.51) Purchased
QD3 Male Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) *Black* (£8.38) Purchased
X10 Bitspower Connection 1/4 inch to 16/11mm - Deluxe White (£9.98) Purchased
X2 Bitspower angle 1/4 inch to female 1/4 inch - Deluxe White (£7.99) Purchased
X3 Bitspower 1/4" Thread 7.5mm Extension Socket Deluxe White (£4.49) Purchased
X15 Bitspower G 1/4" Deluxe White Rotary 90 Degree IG 1/4" Adapter (£10.99) Purchased
X10 Bitspower Multi-Link Adapter Mini 1/4 inches - Deluxe White (£5.99) Purchased
X2 G1/4" Deluxe White IG1/4" Extender-40MM (£9.99) (only sold in america now) Purchased
12/10 Clear Acrylic Tube (12mm x 1mm x 500mm) Plastic Plexiglas Perspex Pipe (£7.54) Purchased
Coolant:
X2 Mayhems Pastel - Ice White Coolant 1L (£14.99) Purchased
Mayhems Fine Silver Kill Coil (£4.50) Purchased
Mayhems Biocide 10ml With PH Testing Kit (£5.99) Purchased
), the place my keyboard would be placed and where the monitors would eventually go for optimal placement.
good work who ever made them! I was concerned but no more.
D
