- 30 Jun 2012
ps anyone want a brand new motherboard..... its great lol
Have you tried another Psu? It could be a power issue.
well it lasted 4 hours before powering down again .....
witts end
The only other thing I can suggest at the moment, is maybe try another kettle lead and a different wall socket.
What are your Cpu temps , maybe monitor the temps.
Was this a new build ?, when you built it did you do a clean install of Windows or are you trying to use an old install of windows from another computer ?
One thing that has crossed my mind could the motherboard be shorting on the case!, one thing to try is run the system external to the case.
^I would do this next. Take it all apart and place the mobo on a piece of cardboard or similar and build it up outside the case.
Have you checked the CPU/GPU temps at all? Maybe try the graphics card in the other slot to rule out a dodgy slot being the cause.
