Hi,
I am looking to buy a cyclocross bike soon as a winter bike and for when i want to do a bit off road.
I'v been trying hard at this challenge. Been going out on road rides in the pitch black after work. I'm well lit up at the back and my front lights are good enough to see where i'm going up to around 22-23mph, but i still dont feel comfortable on the road in the dark. I'v never done it before and i probably wont be doing it again after i'v finished the 500.Good job, you've pulled that out the bag over the last couple of days. What I would give to be sat on 400k+ right now.
Planet-X have some great deals on frames just now if you decide to build yourself. The Uncle John cyclocross frame looks good for just £175. Only problem is that it has mounts for disc brakes only and there is currently nothing with road style shifters that works with hydraulic discs (unless you're spending huge money) and cable discs are not particularly good.Hi,
I am looking to buy a cyclocross bike soon as a winter bike and for when i want to do a bit off road. once i've sold my kite surfing kit.
but i dunno what to go for or quite sure on budget as it will depend on how much my kite surfing kit goes for..
But say up to £1000-£1100
I like the look of the cube cross race
or don't mind buy a frame and forks set and buy the parts separately and built it.
but what would you suggest?
Thanks
cheers. will take a look. would it be worth waiting a while and try and get my budget up to 1500/600 ?
that looks good http://www.planet-x-bikes.co.uk/i/q/CBOODDRIV/on_one_dirty_disco_cyclocross_rival
[DOD]Asprilla;23454677 said:Lack of guard mounts would kill it as a winter ride for me.
Really considering a turbo after the over indulgent christmas.
Not sure I can afford one though...
Oh well....today's the big one. At least 80 miles, and possibly 100 to finish off my Strava 500 challenge.
Picked my trax satori up for £120 this year. Sure you can find one second hand for about £80–90
Hi guys. I spent most of the morning changing the tyres and brake pads on my Specialised Allez. I spent forever trying to get the rear brake pads positioned and aligned nicely. As I was fitting the pads I realised my back wheel is slightly buckled, meaning I can't put the pads too close to the rim.
I've done the best I can but it means that when pulling the brake lever (Shimano 2300 STI) I have to pull it pretty much all the way to the bar. If I tighten the cable any more then it moves the pads too close to the rim and it rubs on the bent patch.
Obviously the best thing to do ere is straighten the wheel/buy a new one. But in the meantime, is there any temporary fix I can do? I'm hoping there's a screw somewhere that means moving the lever a little bit pulls the cable a lot. There's a couple of screws around the shifters but I'm not sure what they do![]()
Tough ride out Hamilton way today - wild and v windy! Went to do a quick loop over the hill at Whitehill wind farm and got there to find i couldn't even see it due to the cloud of sleet and hail sat over it. Felt good to hit the top though.
http://app.strava.com/activities/34736153
Didn't see any other roadies out at all today either. Unusual for a sunday round here. Just a couple of mountain bikers coming off the hill as i went up it.
