I drink tapoline / council pop. I buy about 5 litres of bottled water per week to water my reptiles, and to use in the misting system for them. I do not want artificial flouride and chlorine traces in the water meant for exotic species.
There's a theory that oestrogen isn't properly removed from our water, which men go on to drink and can cause them to be infertile.
How does the oestrogen get there? By ladies flushing things with wings and strings down the bog.
If I want to drink water, I crack open a tap, fill a glass and drink it. Job done.
Tap water here int' north is fine. Crystal clear! Plus it has a little bit of fluoride or something in which apparently helps whiten your teeth a little every time you drink it (supposedly).
You only need to go 15 miles down the road though and the water is hideous, such a strange taste.
I drink out of lake windermere![]()
It's been a long time since I heard this, so my info may be out of date or I'm remembering it wrong... but doesn't fluoride replace the calcium in your teeth, effectively weakening them?
It was certainly something like that that used to be in a lot of toothpastes and was causing problems...
Buxton or Highland spring actually.
I can taste the difference.
I drink it to keep hydrated. As long as it's safe I don't give a damn where it comes from!
In thailand the imported 'evian' was around £4 a bottle where I was, insane!
