Was this board supplied by OcUK or have you changed over to socket 2011 from socket 1155??
Why dont they use all sata 3 ports these days whats the reason ?
rjk say cos it will cost more price on the board but I think it bit silly for manufacturers to charge more for extra Sata 3 ports
i would have thought that would be common sense.
cost????
how is that not blindingly obvious.
of course sata3 will cost more, it entirely depends on the controller.
a marvel sata controller is much much cheaper to implement than having the sata3 controlled by intel off the chipset.
Can't wait for your a10-5800k one.. (did i guess right?)![]()
Loving the Award badges at the end..
Correct, I have also just sorted a 6670 in my wanted thread, so I can "dual" it up.
Thats Ethermasters doing![]()
and Cheers Doomedspeed glad you like it.
take it back under dsr if it was bend out of the box
Why bother, if it works it works, slight bend it it won't matter. He did also state it was sometime ago, so guessing th DSR window has closed!
Then how the person be able to screw in the case if it was badly bend ? If it was me, I will sent it back, no doubt!
I've had many slightly bent boards, all screwed in fine. Admittedly that is an extreme example, but I suspect it worked fine. I'm also guessing the photo makes it looks worst than it is.
You're famous on facebook stulid! Gigabyte have posted your review on their FB page. Great review btw, that's a beast of a board.
Looks fantastic, what OC did you settle on with that combo in the end, and how long was it tested on prime with all the cores pegged?
well done Gigabyte !
