Is there an appeal system for penalty? I got a 24h penalty but I only disconnected from "safe to disconnect games" and didn't say anything mean in chat. I didn't do anything wrong and still got 24hour "ban"
You got put into low priority. You'll get no random item drops, people are generally horrible in it (verbal etc..) but you can still play. 24hrs indicates you left a game in progress though, this is the standard "timeout" punishment used by Valve. You can get one for verbal harassment too but it seems unlikely you got this.
It actually tells you in red text (and to your team mates if you queue with them) why you're in low priority on the queue up screen.
If you can find it, old thread had quite a bit on new heroes but I'll repeat the usuals that get mentioned.Any advice on characters that are 'easy' to play?
Supports: Lich, Vengful Spirit, Jakiro (all have great lane presence)
Easy to learn Strength heroes: Slardar, Sven, Sandking (only take SK with another stunner)
Carries: (ranged) Sniper, Drow, (Melee) Juggernaut, Anti-mage.
Queuing with a friend? Lina + Sandking + level 3 kills anything that can't stun back. Naga Siren + Any stunner (lion works well) kills anything that can't stun back from level 2/3 onwards (net into stun into naga images with backup E)
All the above have either a cut down list of spells (less to press in a panic) or an easy to learn combo. Ask this thread for more info. There are loads more "easier" heroes, this is just a small snapshot of solid allrounders. Not all heroes in Dota have a skillshot like LoL and you have a tiny mana pool - don't burn your spells in lane unless you have a good reason (scare them, a gank, etc...) I'm amazed you used fixed camera to be honest but if you want to replicate it partially, double tap and told select hero bind.
That's plenty of advice and tips. Need to learn to last hit properly. Seems like it's much harder in Dota!
Don't be afraid to ult 2 of them (eg both their stunners), if you kill 2 then the other 3 arn't going to be an issue.
