- 27 Mar 2003
So I have just got a new work pc with a vtx3d 7770 xtreme gfx card in it. On the back it has the following connectors:
2x dvi
1 dp
1 hdmi
so i am trying to get eyefinity work and for the love of all that is holy I can't get the third monitor enabled.
I am using windows 7 64bit with the latest cat drivers.
I have tried a dp adapter that we had for another machine (This works fine when only one dvi/hdmi connector is used but as soon as the second (dvi/hdmi) connection is used the third monitor refuses to power up.
So I have had a bit of a google and it seems that I need an active adapter which may solve my problem.
If this is the case then will this work for me:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-057-HS&groupid=701&catid=1915&subcat=1577
Thanks in advance.
2x dvi
1 dp
1 hdmi
Thanks in advance.
you got no proof dude
