anyone bought e-liquid from here before>>>
http://www.simplyeliquid.co.uk/
seems awfully cheap....30ml bottles for £7-8
Ordered myself a SS Vamo, 2 panasonic batts, and 5 new mega DC cartos. Ouch, my wallet! Still, with the help of the chaps at UKV I kept it all under £70. Hopefully this will last me a while! I think I may need to finally stock up on some nic base as wellOn my last bottle
stupid work computer wont let me edit my post.
i think i am going to order this
52mg nic 250mlfor £36.98 some no-nic PG from the same site then some flavor concentrates from flavourart.
cant wait to don a white jacket and look like a mad scientist in the kitchen,
Self-made is where it's at. I would pick up some VG as well, or else you'll find that it'll be a bit on the harsh side with less vapour.
The nic base is 52mg VG so will be diluted down to about 18mg i estimate with flavour and stuff it should be arround 65/35 PG VG mix
would you recomend getting some more VG to bring that up to around 50/50
I can't tell you anything about those cleros as I've never seen ones like them. The batteries are tiny. I'd use one of them up in like an hour of vaping (I'm a very heavy vaper) I wouldn't suggest anyone buy one under 900 mah. I have small ones like that I use when I want something tiny that I can have in my hand and others can't see it.
Thanks Brennen,
well my kits ordered, cant wait to make a start
