7dayshop do a varible nd filter at several sizes, i think it might have a colour cast, but only used it photographing the fireplace so not sure
Hey Gaffer,
Not going to go the welding glass route...this is going to be an almost once in a lifetime trip for me. So a proper filter system it is.
Thanks,
Jake
my variable one can go pretty much solid black, but i dont know what thats equivlent to in stops, doesnt say on 7dayshop website
but my camera only does upto 30sec, or "bulb" upto 30mins or something, so id have to get something to hold the shutter button on remote closed![]()
Make sure you get a good circular polariser. That doubles up as a 2 stop ND filter anyway. If you are a re shooting a modern body then ISO 50 is very good, combined with stopping down to f/16 you are going to get a plenty long enough exposure for most shots like waterfalls, streams etc. and it should be long enough for oceans shots as the sun sets.
Like lens, filters are expensive but depreciate slowly. Look second hand and you may find that over a 5 years period you have barely lost any money if you need to resell it.
A circ polariser as well as the 10stop? o.0
Or am I being a noob?
This.......
CPL and ISO50 gets you a long way, it's the way I would do it.
My Contax actualy goes down to ISO25 so gets me another stop.
Also probably no harm in over exposing by 1 stop..... This could for example mean a 1 second exposure instead of a half, which would be a considerable amount more movement in the subject.
Experiment before splashing out ........
Iso 50 is a false iso. It's no different than overexpsing and then reducing exposure by a stop in post. Over exposing an additional stop, you end up with 2 stops of everexposure. This is not a good idea, particularly with landscapes as you will end up with unrecoverable highlight detail.
Op if your going to make the effort and expense to undertake such a trip then don't cheap out on filters.
 ......   My vintage Contax ND does a genuine 25.
